Troubleshooting iVend Replication
iVend Cloud is a Software as a Service offering that encompasses the full capabilities of the iVend Retail omnichannel solution suite with fully managed services delivered via a hosted infrastructure. iVend Cloud offers seamless communication between the head office and stores.
iVend Cloud comes with a replication engine at the head office. This replication engine has a Replication Dashboard which displays the real time status of a transaction in between head office, store, and Offline POS. The stores with multiple POS can be easily managed and monitored at head office for the replicated data. The Replication Dashboard is viewable through any device which supports an internet browser
The iVend Replication might not work in the following scenarios
  • When Store goes offline
  • When iVend Replication Services are not started.
  • When the iVend Configuration Manager settings are not configured
  • When Replication Dashboard displays POS even after deleting the POS
The following are the steps to troubleshoot the replication issues listed above:
When Store goes Offline
When the network connectivity of the iVend store server goes down for any reason, the replication will not take place between the iVend store and the iVend head office.
The replication will be established only when the iVend store server comes on the network and connects with the iVend head office. Ensure that the iVend store server / offline POS are always connected with the head office.
The iVend replication services are installed on the Store Server and Offline POS machine. When the iVend Replication service stops or is not started for any reason, the replication between the head office and Store or Offline POS stops.
Go to Run, type “services.msc” and open the services on the Windows machine. Search for iVend Replication Services. Right click on the iVend Replication Services and start / restart it. This re-establishes the connection of the Store, offline POS and Head office server machine.
The iVend replication will not work when the configurations in the iVend Configuration manager are not done or the information entered is not correct. The following is the configuration on the Store Server are required to run the replication smoothly:
Field
Description
Company Name
The system  auto populates name of the for which iVend is configured
Server Name
Name of the Store Database Server Machine
Database Name
Name of the Store Database Name
User Id
User id used for login to Store Database
Password
Password used for the above User Id
Enterprise Server Address
Enter the Enterprise Replication Server Address in format
On Premise
 "http://[ Enterprise Server IP Address or Name]/ iVendReplication/iVend/Hubs".
On Cloud
https://<yourcompany.ivendcloud.com:8642>/iVendreplication/iVend/Hubs
Ensure that the correct server name, database name and enterprise server address information is filled in the iVend Configuration Manager form to run the replication smoothly.
In case of Offline POS, the following are the configuration required on the iVend Configuration manager:
Field
Description
Server
Local machine name
Database
Enter preferred Name of the database to which the backup database file from the Enterprise server is to be restored
User Name
Login Name is login username for the SQL Server
Password
Login Password is password for username to log in the SQL Server
Backup file
Select the Backup file saved on the local machine in the steps mentioned above section.
Service Address
On Premise
http://[ Enterprise Server IP Address or Name]/ iVenReplication/iVend/Hubs".
On Cloud
[Cancel]
Click to cancel the settings
[Save]
Click to Save the settings
 P.S. The service address format should be followed while updating the configurations.
The Replication Dashboard displays all Store POS and will keep displaying them even after they are deleted from the environment. This is because the Internet Information Server (IIS) components related to the deleted POS are still present.
In this case Reset the IIS. Resetting IIS will remove the components related to deleted POS. Once IIS is reset, reopen the iVend Replication Dashboard and the deleted POS will no longer be displayed on the replication dashboard.
Follow the above mentioned troubleshooting information to resolve the replication issue. If you are not able to resolve the replication issue after following the above mentioned information, please contact support@citixsys.com for further assistance.
    • SALES REPLICATION ERROR
      Environment: IVend 6.6 with SAP B1 Problem statement: After Applying patch 7723 for version 6.6 sales are not replicating. Did the test by modifying an article and after replicating but the sales did not. Below troubleshooting steps followed: 1.- ...
    • Replication service Start error on Offline POS
      Environment: iVend 6.6 Problem Statement: While starting replication service from Services in offline POS, the below error is coming. Symptoms: Changes done in iVendReplicationWinService.exe.config file on below path C:\Program Files ...
    • Replication not working
      Environment: iVend 6.6 Problem Statement: Replication service not working due to controller application Error Screenshot: Solution: - This issue happened due to there’s an error showing from controller application when customer removed this ...
    • Replication Issue - Connection Status Color is Black
      Version 6.6 Issue The customer has a problem with the connection status color of the stores. Replication connection status at the replication dashboard from stores to HO appears in Green but from HO to stores the status color is in Black. Below are ...
    • Replication from HO to store or from store to HO is freezed
      Environment: 6.5 updates 6 and before Problem Statement: Replication is not working between store and Enterprise Resolution: One of the basic reasons for replication not working can be the replication service not working correctly or there is SQL ...
