Tray id is not generating and tray status is showing zero for random orders
This article is for Internal Use
Tray id is not generating and tray status is showing zero for random orders that customer was placing from POS (iVend Optical)
Proposed Solution/Workaround:
This issue has been fixed by the CD Team.
POS showing zero "Avaialbe to Sell quantity" for an item.
Problem: POS showing zero "Available to Sell quantity" for an item. However, the Available quantity and In-Stock quantity for the same item is greater than zero. Solution: When POS User mark the checkbox "Reserve Quantity" while creating delivery ...
Price Showing Zero in POS Transaction
Environment: iVend 6.6 Query: Product price showing zero during Sale transaction in POS while price available in Price List Resolution/Work Around: Please open product in SAP and check if its marked Zero value Item or not ?
Transaction ID not generating for Suspended Transactions
Environment: iVend 6.6 Problem Description: The transaction ID was not generated for suspended transactions. Symptoms: None Resolution/Work Around: If the POS is not generating a transaction ID for a suspended transaction. We need to check below ...
PmtGiftCertificateLog Table Showing SourceKey Zero (0)
Environment: iVend Retail 6.6 8567 Problem Statement: PmtGiftCertificateLog table showing SourceKey zero. Symptoms : N/A Resolution/Work Around: N/A Recommendations /Suggestion: Whenever the SourceKey is 0 in the PmtGiftCertificateLog table, it means ...
iVend Replication showing red symbol in connected status on the replication dashboard
Environment : 6.6 integrated with SAP Symptoms: Replication was not working from Store to Enterprise and Vic Versa. Problem Statement : Enterprise and store showing a red symbol in connected status on the replication dashboard. Resolution/Work ...
