Transaction Mode not Changing on POS for Specific Customer
iVend 6.6 with SAP B1 10.0
Transaction Mode Sale Order Not Picking on POS for specific customer.
User Request
Issue resolved after following the below steps.
1: Login in Enterprise Management Console.
2: Go To: Operations Tab >> BP Masters >> Click on Customers>> Scan problematic Customer >> Click on Edit Button.
3: Make sure the “Can Order Items” check box is checked. Check below Image for the same.
Remove Customer Master which has transaction and also remove those customer which has no transaction
Environment: Ivend 6.6 Problem statement: Need to Remove Customer Master which has transaction and also need to remove those customers which has no transaction details. Resolution/Work Around: 1. Remove customer master which has no transaction ...
POS - Transaction mode change event
Introduction: iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows to extend business logic either in Management Console or at the Terminal POS. The addon framework allows deployment of ...
Introduction iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows to extend business logic either in Management Console or at the Terminal POS.The addon framework allows deployment of ...
Scan Sequence Resolution
Cash Customer for Specific POS
Environment: iVend 6.6 Problem statement: Is it possible to assign a default cash customer for a specific POS or with a specific user Resolution/Work Around: It is not possible to assign a default cash customer for a specific POS or with a specific ...
