iVend 6.6 with SAP B1
System.Exception MethodName SendPostRequest, WebException Invalid column name 'U_status1'. At ReplicationSBOIntegrationWinSer.IntegrationObjects.Base.IntegrationBase.SendPostRequest(List 1 listOfQueries, String isStoreProc)
Symptoms :
U_DCTOENC" is a 'Document' type user table that contains few Standard fields.Status field is already created by SAP as a standard field in the same table if incase user created another "u_status" field in the same UDT which is not recommended.
so in that table "Status" and "U_Status" are two fields and therefore it is causing issue.
Delete the "status" field in User defined Fields Management from the DCTOENC table.
It is recommended to do not create any field that is part of standard fields.
