iVend 6.6 SAP with Business One 10.0
Below error message stuck in iVend Integration failure from iVend To SAP.
Warehouse Locked in SAP on this Product Master I00005
Follow below steps to solve the problem.
1: Login in SAP Business one.
2: Click on Inventory Module >> Click on Item Master >> Press CTRL+F
3: Type Product Code in Item No. column, then Press enter button.
4: Find the warehouse, uncheck the locked check-box and click on the Update button.
5: Open integration failure Log Retry the failed Transaction.
N/A
