6.5 Update 6
You may come across the integration issue in iVend 6.5.6, where record stuck in integration monitor with below error.
“System.Data.SqlClient.SqlException (0x80131904): Subquery returned more than 1 value. This is not permitted when the subquery follows =, !=, <, <= , >, >= or when the subquery is used as an expression. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1
In the above-listed sample screenshot, the record stuck above shows that it is a Transaction Type record . i.e. ( 143 Source Type).
Based on this you can use Integration procedure Integration_Transaction to check its details using the transactionKey:
To Check the details execute the below Store procedure.
Exec Integration_Transaction 9000000000189266
Run below scripts to check the other details of the transaction :
Select HasSales,HasFulFillments,HasDeliveries,HasGiftCertificates,HasSaleExchanges,* from TrxTransaction where TransactionKey=9000000000189266.
Select HasFulfillment,HasSerialNumber,HasDiscounts,IsExchange,IsPromotionApplied,* from TrxTransactionSaleItem where TransactionKey=9000000000189266
In this case, we observed that the value of the column “HasFulFillments” in table “trxtransaction” was as 1.
Thus, the transaction was related to fulfillment, so we checked the below-related tables of fulfillment.
Select * from TrxTransactionFulfillment where TransactionKey=9000000000189266
Select * from TrxTransactionFulfillmentDetail where TransactionKey=9000000000189266
Select * from TrxTransactionFulfillmentDetail Where FulfillmentKey=9000000000202102
Backup Query:
Select * into TrxTransactionFulfillmentDetail_bkp180320 from TrxTransactionFulfillmentDetail where FulfillmentKey =9000000000202102
Delete the duplicate records from TrxTransactionFulfillmentDetail table by selecting concerned FulfillmentDetailKey :
Delete from TrxTransactionFulfillmentDetail where FulfillmentDetailKey='FulfillmentDetailKey need to be deleted'
Once done, retried the failed integration record and checked, it was successfully integrated from iVend to SAP.
