Store Reinitialization : Till assignment Error "Object Reference not set of an instance..."
After Store initialization ,User doesn't able to assign the tills on POS screen.
​iVend 6.6 with SAPB1
When store is initialized, user should consider below points
Replication should be clear from store to HO.
1.Till should be proper closed from all the store so that it could be replicated completely on HO
2.Later user can cross checked  Sales / till status on HO MC
3.Create Store backup file on Enterprise, considering Transaction Restore Cut of date
4.Initialize the store on store machine with backup file.
Notes
Note/Suggestions :
With such error message, suggest to check if any open till still available with previous business date in Store MC Till Screen.
If yes, then need to close it from Store MC . If getting error to close it, check its Till tables in Store database base.
