Item in order mode can not be voided
iVend Retail 6.6 8929
During Special Order as the scenario customer wants to change the items in their Special Order but when we try remove the item in the Special Order and add the new item then below  Error message " showing  item in order mode can not be voided "
Can not Change the items  while  Special Order edit  process
 For solving this issue, we suggested that at the time of special order edit you cannot void item, but you can make quantity 0 for that item with -edit  button
Refer attached screenshot
    • How to Cancel specific item in a Special order from iVend
      Product version: 6.6 Problem statement: How to Cancel a specific item in a Special order in iVend Resolution/Work Around: To achieve the above, one can change the quantity of the item to 0 and save the order. Please find the detailed steps listed ...
    • Transaction Mode not Changing on POS for Specific Customer
      Environment: iVend 6.6 with SAP B1 10.0 Problem Statement: Transaction Mode Sale Order Not Picking on POS for specific customer. Symptoms: User Request Resolution/Work Around: Issue resolved after following the below steps. 1: Login in Enterprise ...
    • Item Matrix Global Settings
      Item Matrix Global Settings This feature allows the user to define the Global Code and Inheritance settings for Matrix Items. These settings are used as the system defaults and are inherited to the Matrix products in the first instance. The user can ...
    • Check the voided items from the POS
      Product Version: iVend 6.6 with SAPB1 9.2 Problem statement: How to check the voided items from the POS? Symptoms: Users make one voided transaction on iVend POS and need to check on the POS screen as well. Resolution/Work Around: iVend POS doesn't ...
    • Selling any item that is zero price, and putting a zero value into the order, cannot complete it
      Version 6.5 Update 5, not the version-specific Issue When selling any item that is zero price, and putting a zero value into the order, then cannot complete the sale. Observations Allow zero price is enabled at the enterprise, and this event has been ...
