SQL Queryfrom Suspect mode to normal
 ***************************** Internal to Citixsys Support Team*********************************
iVend 6.6 7989 with SAPB1
Problem Statement :
iVend database got Suspect Mode and there is need to move to Normal Mode.
Note : It should be discussed with Level 3 team first before using this one
SQL Queries :
Option 1:
EXEC sp_resetstatus 'yourDBname';
ALTER DATABASE yourDBname SET EMERGENCY
DBCC checkdb('yourDBname')
ALTER DATABASE yourDBname SET SINGLE_USER WITH ROLLBACK IMMEDIATE
DBCC CheckDB ('yourDBname', REPAIR_ALLOW_DATA_LOSS)
ALTER DATABASE yourDBname SET MULTI_USER
 Option 2:
--to return to multi-user mode:
ALTER DATABASE 'yourDBname';
SET MULTI_USER Use database_name
GO
ALTER DATABASE database_name SET SINGLE_USER
GO
DBCC CHECKDB('database_name', REPAIR_REBUILD)
GO
ALTER DATABASE <database-name> SET MULTI_USER
    • Change from Mixed Mode to Separate Store
      ------------------This article is for only internal use ------------------------ Product version: iVend 6.6 with SAPB1. Problem statement: A Store was created in mixed mode however it was required to be created as Separate Mode Store Proposed ...
    • compatibility version SAP & SQL Version
      Product Query Customer currently using the SQL version 2016 in HO and stores in 2008 express . SQL 2019 and higher version will support ivend 6.6? SAP Version 10 and Pl 2405 and higher PL version will compatible with ivend integration ? Answer As per ...
    • POS - Transaction mode change event
      Introduction: iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows to extend business logic either in Management Console or at the Terminal POS. The addon framework allows deployment of ...
      Introduction iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows to extend business logic either in Management Console or at the Terminal POS.The addon framework allows deployment of ...
    • How Online POS Operates in Comingle Mode
      Problem statement : How Online POS Operates in Comingle Mode iVend version : 6.6 8929 Symptoms: NA Resolution / work around : To configure and run the Online POS in Comingle mode, follow the steps below: 1. Store Configuration Create a Store and ...
