iVend 6.6 Patch 8024
Problem Description:
Show manufacturing number in serial selection screen.
Scenario:
How can we show the manufacturing serial number in the POS serial number selection screen?
At POS only the serial number is visible (which is an internal serial number, and not from the manufacturer).
1) On the sale edit screen, it will display only the serial number as well as Expiry date of the product of the product. It is System by design.
N/A.
We have explained to customer that setting data for manufacturing serial number will not show in the sale edit screen ; search grid column not for selection views these are hardcoded to display only existing fields i.e. serial number and expiry date it is system by design.
