Version :
iVend 6.6, 6.5 , 6.4
Problem Statement :
While launching MC/ POS one may encounter below pop up.
ShockWave Player Error
Symptoms :
Resolution :
Workaround :
1. Login into iVend Application again.
2. You will get the the popup again which have mentioned in your description box.
3. Just verify and cancel it and you will get the plain iVend screen.
4. Click some where on iVend blank application and wait for some time.
5. Now you can check iVend Application login page shown.
6. Login with User Id and Password and move to Home Page.
