iVend 6.6 Patch 8453
Reg : Replication dashboard issues
Customers updated the patch from 8024 to 8453. After upgrading the patch, they didn't see the replication offline POS / store disconnected time in the replication dashboard.
This parameter is very helpful to identify the offline POS disconnected time, and very helpful to monitor the replication status,
Before update Version 6.6.8024
After update Version 6.6.8453
Yes, fields "Connected at ","Disconnect at" are not available in the latest provided replication monitor screen as sometimes, they don't display the correct time. So new fields "Records Received ( 5 mins)" and Record Processed (5 mins) are available in the Replication monitor.
