Reg : POS Layout change - Product Search layout
iVend 6.5.6
Problem Description :
Need to remove the below label in POS - product search page.
Scenario :
Client need to remove the highlighted labels from POS.
1) Check the POS Log  File of iVend.
2) Suggest Client to check if user has rights on iVend MC---> Security Roles (attached to User) > Search Grid & Search Grid Column.
Symptoms :
N/A.
We suggest client to check if user has rights on iVend MC ---> Security Roles (Attached to User) --> Search Grid & Search Grid Column ,Changes working fine.
    • Scan Sequence Resolution
    • How to add more search criteria in Product Search Screen
      Requirement: Need to add more search criteria in the Product search screen. E.g. Add Description2 as search criteria. Steps : Steps to add more Product Search Criteria at POS level. Open POS. 2. Click on the product search button. 3. Right click on ...
    • Transaction Search Error " An Error has been encountered during the search function" at POS
      Product Version: iVend 6.6 Problem Statement: Users encounter the error "An Error has been encountered during the search function" at the POS when attempting to search for transactions. Symptoms The POS log file shows an issue with the API ...
    • Steps to change Date Format for the POS operations or Transaction search screen
      Steps to change Date Format for the POS operations or Transaction search screen: - 1. Open the Management Console 2. Administration > System Initialization > System Display Settings. By default, iVend initialize with Date Format M/d/yyyy. 3. To ...
