*******Internal to CXS Support***********
iVend 6.6 integrated With SAPB1
Problem Statement :
Sales Difference between iVend & SAP against particular date transacation.Customer is using Transaction consolidation.
Symptoms: NA
Below are the query we can used to trace issue
Query to find no of transaction of particular date
Query1:-
select count(distinct TransactionKey ) from trxtransaction with (nolock) where
IsVoided='0' and IsSuspended='0' and BusinessDate>='Put Problemtical date' and BusinessDate<= 'Put Problemtical date'
Example
IsVoided='0' and IsSuspended='0' and BusinessDate>='2022-03-28' and BusinessDate<= '2022-03-28'
Query2:
Query to find to check all transaction of particular date exists in RepIntegrationLog
select count(distinct SourceKey )from RepIntegrationLog with (nolock) where sourcetype='143' and sourcekey in (
select TransactionKey from trxtransaction with (nolock) where
IsVoided='0' and IsSuspended='0' and BusinessDate>= 'Put Problemtical date' and BusinessDate<= 'Put Problemtical date')
Example:
IsVoided='0' and IsSuspended='0' and BusinessDate>= '2022-03-28' and BusinessDate<= '2022-03-28')
Query3:-
Query to find all transaction exists in transaction Table are part of consolidation or not
select count (distinct TransactionKey) from ConTrxTransactionMapping with (nolock)
where TransactionKey in (select TransactionKey from trxtransaction with (nolock) where
Example:-select count (distinct TransactionKey) from ConTrxTransactionMapping with (nolock)
where TransactionKey in (select TransactionKey from trxtransaction with (nolock) where --CustomerKey='91f5e265-041b-4e20-bf7a-cd86d168816e'
Note:-If count of query1,quey2,query3 are same its means all transaction are part of consolidation and present in RepIntegrationlog
Query4:-
Query to find no of consolidated transaction key against particular date
select distinct ConsolidatedTransactionKey from ConTrxTransactionMapping with (nolock)
Example:
Query5:-
Query to find no of productkey against consolidation transaction matched with trxtransaction sale item based on ConsolidatedTransactionKey from query4
select count(distinct productkey) from ConTrxTransactionSaleItem where transactionkey='ConsolidatedTransactionKey from query4'
Example:
select count(distinct productkey) from ConTrxTransactionSaleItem where transactionkey='0159B693-68F0-42FB-A3F2-5C84C81BB63A'
Query6:-
select count (distinct productkey) from TrxTransactionSaleItem where transactionkey in (
select TransactionKey from ConTrxTransactionMapping
where ConsolidatedTransactionKey='ConsolidatedTransactionKey from query4)
Example:
where ConsolidatedTransactionKey='0159B693-68F0-42FB-A3F2-5C84C81BB63A')
Note:-If query 5 and query 6 count mismatch its means there are some transaction missing in ConTrxTransactionSaleItem
Query7:-
Below query to find missing product on consolidation against particular consolidation
select distinct ProductKey into #1 from TrxTransactionSaleItem with (nolock) where transactionkey in (
select distinct TransactionKey from ConTrxTransactionMapping with (nolock)
where ConsolidatedTransactionKey='ConsolidatedTransactionKey from query4')
select * from #1 where productkey not in (
select ProductKey from ConTrxTransactionSaleItem with (nolock) where transactionkey='ConsolidatedTransactionKey from query4')
Example:-
select ProductKey from ConTrxTransactionSaleItem with (nolock) where transactionkey='0159B693-68F0-42FB-A3F2-5C84C81BB63A')
Query8:
Query used to fetch missing data against productkey found from query7 and consolidation key from query4
select * from ConTrxTransactionSaleItem with (nolock) where transactionkey='ConsolidatedTransactionKey from query4'
and ProductKey in (productkey from query7)
select * from TrxTransactionSaleItem where transactionkey in (
and ProductKey in (productkey from query7))
Example:-
select * from ConTrxTransactionSaleItem with (nolock) where transactionkey='0159B693-68F0-42FB-A3F2-5C84C81BB63A'
and ProductKey in ('e17b3b41-0a13-414a-8943-3f6ea87cc6be')
Provide user data from sale table according to requirement of user to create Ar invoice manually on downtime after stop Intgeration and ignore inventory impact
Query8:-
select b.id,a.* from TrxTransactionSaleItem a, invproduct b where a.ProductKey=b.ProductKey and transactionkey in (
and a.ProductKey in (productkey from query7')
Example:-
where ConsolidatedTransactionKey='61E3CCEF-9BEE-47F7-AC8F-17B1AC714515')
and a.ProductKey in ('e17b3b41-0a13-414a-8943-3f6ea87cc6be')
Recommendations /Suggestion: This article is created only for Support team.
