Query used to compare Missing Inventory document between iVend and SAP HANA
iVend 6.6 integrated with SAPB1
We can use below query to compare data iVend and SAP HANA
Note: This query needs to be run on the SAP Database
select a."CreateDate",
      b."USER_CODE" as "User",
    a."TransType" "SAP DocType",
    case
      when a."TransType" = 13 then  'Sale Invoice'
      when a."TransType" = 14 then  'Sale Credit Note'
      when a."TransType" = 15 then  'Delivery'
      when a."TransType" = 16 then  'Sales Return'
      when a."TransType" = 18 then  'Purchase Invoice'
      when a."TransType" = 19 then  'Purchase Credit Note'
      when a."TransType" = 20 then  'GRPO'
      when a."TransType" = 21 then  'Purchase Return'
      when a."TransType" = 59 then  'Goods Receipt'
      when a."TransType" = 60 then  'Goods Issue'
      when a."TransType" = 67  and exists (select 1 from WTR1 x inner join OWHS y on x."FromWhsCod" = y."WhsCode" where x."DocEntry" = a."CreatedBy" and x."LineNum" = 0 and "Quantity" > 0 and y."U_CXS_INST" != 'Y')then  'Stock Transfer'
      when a."TransType" = 67  and exists (select 1 from WTR1 x inner join OWHS y on x."FromWhsCod" = y."WhsCode" where x."DocEntry" = a."CreatedBy" and x."LineNum" = 0 and "Quantity" < 0 and y."U_CXS_INST" != 'Y')then  'Stock Transfer Cancellation'
      when a."TransType" = 67  and exists (select 1 from WTR1 x inner join OWHS y on x."FromWhsCod" = y."WhsCode" where x."DocEntry" = a."CreatedBy" and x."LineNum" = 0 and "Quantity" > 0 and y."U_CXS_INST" = 'Y')then  'Stock Transfer Receipt'      
      when a."TransType" = 67  and exists (select 1 from WTR1 x inner join OWHS y on x."FromWhsCod" = y."WhsCode" where x."DocEntry" = a."CreatedBy" and x."LineNum" = 0 and "Quantity" < 0 and y."U_CXS_INST" = 'Y')then  'Stock Transfer Receipt Cancellation'else 'Unknown' end as "SAP DocName",
    a."CreatedBy" "SAP DocEntry",
    a."BASE_REF" "SAP DocNumber",
    case a."TransType"
      when 13 then (select "U_CXS_TRKY" from OINV where "DocEntry" = a."CreatedBy")--Sale Invoice
      when 14 then (select "U_CXS_TRKY" from ORIN where "DocEntry" = a."CreatedBy")--Sale Credit Note
      when 15 then (select "U_CXS_TRKY" from ODLN where "DocEntry" = a."CreatedBy")--Delivery
      when 16 then (select "U_CXS_TRKY" from ORDN where "DocEntry" = a."CreatedBy")--Sales Return
      when 18 then (select "U_CXS_TRKY" from OPCH where "DocEntry" = a."CreatedBy")--Purchase Invoice
      when 19 then (select "U_CXS_TRKY" from ORPC where "DocEntry" = a."CreatedBy")--Purchase Credit Note
      when 20 then (select "U_CXS_TRKY" from OPDN where "DocEntry" = a."CreatedBy")--GRPO
      when 21 then (select "U_CXS_TRKY" from ORPD where "DocEntry" = a."CreatedBy")--Purchase Return
      when 59 then (select "U_CXS_TRKY" from OIGN where "DocEntry" = a."CreatedBy")--Goods Receipt
      when 60 then (select "U_CXS_TRKY" from OIGE where "DocEntry" = a."CreatedBy")--Goods Issue
      when 67 then (select "U_CXS_TRKY" from OWTR where "DocEntry" = a."CreatedBy")--Stock Transfer
      else 'Unknown' end as "iVendKey",        
    a."InQty",
    a."OutQty",    
    a."ItemCode",
    a."LocCode" "WhsCode",
    A."TransSeq" AS "SAP TransNum",
    a."U_CXS_IINV"
FROM OIVL a
inner join OUSR b on a."UserSign" = b."USERID"
where (a."InQty" != 0 OR a."OutQty" != 0)
and  a."ItemCode" in('Put Item Code') and a."LocCode" = 'Put warehouse code'
order by a."CreateDate";
Run on Enterprise Database
select convert(varchar,a.Created,112) Created,
case        when a.SourceType = -1 then 'External'
          when a.SourceType = 0 then 'Unknown'
          when a.SourceType = 1 then 'GoodsReceipt'
          when a.SourceType = 2 then 'GoodsReceiptPO'
          when a.SourceType = 3 then 'Stock Transfer Receipt'
          when a.SourceType = 4 then 'StockTransfer'
          when a.SourceType = 5 then 'KitBuildBreak'
          when a.SourceType = 6 and a.InQty > 0 then 'Goods Receipt InventoryCounting'
          when a.SourceType = 6 and a.OutQty > 0 then 'Goods Issue InventoryCounting'
          when a.SourceType = 7 and a.InQty > 0 then 'Refund'
          when a.SourceType = 7 and a.OutQty > 0 then 'Sale'
          when a.SourceType = 8 then 'LayawayTransaction'
          when a.SourceType = 10 then 'GiftCertificateReceipt' when a.SourceType = 11 then 'GiftCertificateStockTransfer'
          when a.SourceType = 12 then 'GoodsReturn' when a.SourceType = 13 then 'InventoryReconciliation'
          when a.SourceType = 14 then 'StockTransferCancellation' else cast(a.SourceType as varchar) end as [iVend DocName],a.SourceKey [iVendKey],
          a.InQty, a.OutQty, x.TransType [SAP DocType],
          x.BASE_REF as [SAP DocEntry], x.TransNum [SAP TransNum],
b.Id as ItemCode, c.Id as WhsCode,
a.SourceType [iVend SourceType]
from InvInventoryItemLog a
inner join InvProduct b on a.ProductKey = b.ProductKey
inner join InvWarehouse c on a.WarehouseKey = c.WarehouseKey
left join SBOInventoryUpdates x on a.SourceKey = x.RecordId and a.SourceType = -1
WHERE B.Id='Put Item Code' AND C.ID='Put warehouse code' and (a.InQty != 0 OR a.OutQty != 0)
order by a.Created;
Recommendations /Suggestion
