Problem statement
Environment iVend Retail 6.6 7989 & SAP Business One 9.3
Promotion was not applying because of Configuration; in such configuration we need to scan product from Get Side all product category.
Issue resolved after suggesting to uncheck “Is Mandatory” Check box from Get Products and enter value 1 in “Get Optional Count”, Check below image for the solution.
Recommendations /Suggestion
If you check “Is Mandatory” Get Product side, then you need to scan product from all the Get Side configuration.
