Problem In Store Database Backup Restore.
Problem :
Unable to Create Store Database from HO Management console. Script.xml is not created in the backup file.
Reason :
Earlier backups were corrupts because following SQL statement was throwing error as:
Select A.* From InvSerial A With(nolock), InvProduct B With(nolock) Where SerialKey
between '5000000000001' and '5999999999999999' And A.ProductKey = B.ProductKey And B.IsGiftCertificate = 'TRUE'
AND B.GiftCertificateType = 2
AND TRY_CONVERT(NUMERIC(18, 6), SerialNumber) IS NOT NULL
Error Code - Numeric value 'SerialNumber' is not recognized
Resolution -
We had to change the compatibility level of SQL Server to resolve the issue at iVend Enterprise DB Level and Store DB Level.
Following command was executed as:
alter database [CXSRetail] SET COMPATIBILITY LEVEL = 120
    • SQL Table was not found error during database restore on Store
      Problem Statement: Customer tried to restore the backup database from Enterprise on Store Server, the process failed because table TrxTransactionFulfillment was not found at the database. Error Screenshot: Resolution: Verify whether any custom ...
    • Store re-intialization Step
      Product version: 6.5 Update 6 or 6.6 Problem statement: User want to re-intialize the store. Proposed solution: Suggested customer to re-initalize Store by creating Store backup file from iVend Enterprise MC screen only when replication is cleared ...
    • How to debug Error related with store initialization
      Environment : iVend 6.6 integrated With SAPB1 Problem Statement : During the store initialization an error message has been encountered while configuring the Replication service for the store and the store were not initialized. Below is the attached ...
    • Store Reinitialization : Till assignment Error "Object Reference not set of an instance..."
      Problem Statement After Store initialization ,User doesn't able to assign the tills on POS screen. Environment iVend 6.6 with SAPB1 Resolution/Work Around When store is initialized, user should consider below points Replication should be clear from ...
    • Transaction Restore Cutoff Date Behavior in Store/Offline POS Database Backup
      Product Version: 6.6 Product Query: Customers raised a query regarding 'Transaction Restore Cutoff Date' Behavior in Store/Offline POS Database Backup Proposed Solution: The “Transaction Restore Cutoff Date” option available during New Store / ...
