iVend 6.5 update 6
Not able to print transaction receipt/report from management console.
Need to configure Document print profile in Management Console . Follow below steps to set doc print profile.
Login to Ivend MC-->Administration > Retail Configuration > Document Print Profile
Click on New--> Enter the ID you want to create-->Enter Description-->Choose Apply For(Security user or Security Role)-->Check Apply for All Users(if you want to give rights to print for all users)
At last you will see the TransactionDetail, Choose Report to print--> Click on Transaction Receipt-->Click on preview(if you want to get the preview)-> Choose Default Printer(If any)--> Click on OK.
