Environment : iVend 6.6 Patch 8864
Problem Description: POS slowness issue due to selecting any language in preferred language option
Scenario: POS facing slowness issue.
Solution:Go to Human Resources > Select the Employee > Click on [F4 Edit], then go to the
preferred language option and click on cross button and then press [Ok] to save the change made, as demonstrated in
the following screen image.
Symptoms: N/A.
Resolution/Work Around: Go to Human Resources > Select the Employee > Click on [F4 Edit], then go to the preferred language option and click on cross button and then press [Ok] to save the change made. After doing this slowness issue resolved.
