Period and volume discounts do not appear in pos.
Problem
It was reported that some products do not show the desired (as configured in SAP) discounts at POS
Cause
Possible cause is the price update did not integrated correctly to iVend or if integrated correctly , then might not have replicated correctly at store
Troubleshooting
Need to verify the prices first at Enterprise to confirm if prices integrated from SAP to iVend correctly . Once done then need to check the replication part betwen HO- Store.
Resolution
If the investigation does reveal that the prices are not integrated to iVend itself and there are the relevant updates are not stuck in integration channel as well then as a troubleshooting step and possible resolution you can once try to update the period and volume discounts in sap for one of the problematic product.
Once update is made its integration event would be triggered. You can trace that event in the integration monitor as well.
Once integration is cleared the check the price in Enterprise.
Once price at Enterprise is updated, a corresponding event of replication would get trigger to store(s) as well. And once the replication is cleared to store , POS should be seeing correct /updated prices
    • Period and Volume discount expired but discount is still applying at POS.
      Environment : iVend 6.6 with SAPB1 Problem Statement : The issue is found to be happening only in case when user upload items in SAP with period and volume discounts from excel. It was observed that the Special price list was expired however the ...
    • iVend POS - Tender Based Discounts and Surcharges
      What are Tender Based Discounts and Surcharges? This functionality equips retailers with the ability to define discounts and surcharges based upon tender types used by customers for payment of their purchases at the POS. For example, if a transaction ...
    • Discounts issues on POS
      Environment: iVend 6.6 Patch 7915. Problem Description: Discounts issues on POS. Scenario: Discount issues still persist even after upgrading to patch 7915. Solution: 1) Check the product and the discounts applied on the product-on-Product screen. 2) ...
    • Tax rate stuck due to System.Exception: DI: Posting Period Locked
      Problem Statement: Tax code Modified in SAP Business One, the change does not appear in iVend Retail Error: Tax code stuck in Integration Failure Monitor with Error System.Exception: DI: Posting Period Locked"" Resolution: Step 1 : Identify the ...
    • Scan Sequence Resolution
