A patch is a planned software update that addresses multiple issues, improves performance, and adds new features. It is typically scheduled and tested before deployment.
Some of key features are:
Scheduled Release: Part of regular software updates.
Covers Multiple Fixes: May include security enhancements, bug fixes, and feature upgrades.
Requires Testing: Ensures stability across the system before deployment.
Can Be Larger in Scope: May involve extensive changes to functionalities.
Please verify that everyone has the appropriate security rights on HO, Stores, and Offline POS by looking in the iVend Installation folder named "Citixsys" (folder location: C:\Program Files (x86)\CitiXsys).
Note: The current version of iVend Retail must be 8024 or higher in order to deploy this patch (either installed through installer or updated through patch).
April 15, 2024
June 13, 2024
2024_8929
Click HERE to download the Patch
The steps to deploy the patch are summarized below:
To begin the upgrade, download the latest patch from the Portal.
Once downloaded, copy the following folders from the uploaded Patch folder to the directory:
C:\Program Files (x86)\CitiXsys\iVend Retail
ConfigurationManager
Integration
iVendAPI
PatchUpdater
ReportWebViewer
SchedulerService
Manually replace all Offline POS files and directories, except for the "POS" folder, if applicable.
Use Patch Updater to apply updates to the following components:
Database_Patch_Version
ManagementConsole_Patch_Version
PointOfSale_Patch_Version
Replication_Patch_Version
Manually copy all files from the "iVendReplicationWinService" patch folder to an offline machine with the same folder structure. All other replication files will be updated automatically via the replication services.
Patches are vital for maintaining seamless retail operations by fixing errors, enhancing security, and introducing new functionalities without disrupting day-to-day activities. Regularly applying patches ensures stable, efficient, and secure retail software, improving both customer experience and business performance.
