Other Store's Inventory does not display-not updated in POS terminal after the patch update 7583
Other Store's Inventory does not display/not updated in POS terminal after the patch update 7583
Product version: iVend 6.5 With SAP 9.3
Problem Statement:  After the patch update from 7545 to 7583 the inventory from MC and POS terminal does not tally or some items does not display the inventory.
Inventory from the MC
Proposed solution We have provided you the resolution (support team need to apply the latest patch files on the Enterprise on cloud server once you test the same in your test environment first)
    • 6.6 iVend Retail - Patch Deployment Process
      Query: How to plan iVend 6.6 upgrade and Patch update? Solution: Please follow the attached "iVend 6.6 Patch deployment Process" document. Additional Information: Patch deployment process document is available in Download section of iVend retail. In ...
    • Microsoft Azure is available in ivend if yes in which patch level or version
      Product version: iVend 6.6 Problem statement: Kindly update us about single sign on for Microsoft Azure is available in ivend if yes in which patch level or version ?? Proposed solution/workaround: SSO is not feasible through custom development in ...
