Optical transaction menu not available in ivend management console
iVend Retail 6.6 update 6 Patch 7825
Optical transaction Tab not showing in iVend management console.
Optical Transaction menu is not available in iVend management console
Proposed Solution/Workaround:
Resolution steps are below
1:- Login in the management console.
2:- Go to:- Administration >> Employee.
3:- Select employee open in edit mode and check the check box [Is tray status allowed]
4:- After checking the check box restart management console so that optical transaction becomes visible.
