Not able to integrated Sage X3 newly created product in iVend
iVend Version 6.6 With Sage X3
New products were created in Sage X3 but not able to integrate with iVend.
There is a need to check retailinitialization.xml if it is corrupted or not . If the file is corrupted, you need to rebuild the same file and after that records will process.
Such activities should be done by the Sage X3-iVend Support/Dev team.
