Not able to create stock transfer more than specific qty.
Not able to create Stock Transfer more than 40 Qty.
Error Message: Cannot save list. List not valid.
Error-,UOMQuantity cannot be more than allowed maximum value.
Propose Solution:
Login in Management Console.
1: Go to Administration >>> Application Setup >>> Validation Rules.
2: Check if user created the validation rules for Id “StockTransferRequestDetail-UOMQuantity”, with MAX Value.
3: Click on Edit button on Id“StockTransferRequestDetail-UOMQuantity” Increase Qty and click OK.
    • Stock Transfer Transactions with an ERP
      Stock Transfer Transactions with an ERP (SBO in the Backend) In this article we talk about 4 important transactions in iVend Retail. This article describes i. (i) Stock Transfer Request ii. (ii) Stock Transfer Request Received iii. (iii) Stock ...
    • Query Regarding Stock transfer receiving
      Environment: iVend 6.6 Problem Statement: Query-1: When the employee enters a file containing a group of barcodes into the system for Stock transfer shipment, the system does not aggregate quantities for similar codes, but creates lines according to ...
    • While making stock transfer request not able to edit any filed present in stock transfer request
      Environment: iVend 6.6 Problem Statement: We are trying to make a stock transfer request from iVend MC, but while making a stock transfer not able to edit any file in stock transfer as all the is non-editable. We also checked the validation rule for ...
    • iVend Stock transfer insufficient quantity in intransit
      Problem Statement: At the time of stock transfer customer was facing insufficient quantity in intransit - but the stock at intransit was showing sufficient on View InventoryEnvironment: 6.5 Update 6 integrated with SAP 9.2. Symptoms: User was not ...
