No Management console found in the management console selection screen.
iVend Version:
6.6
Issue:
Not able to select MC in management console selection screen while login to MC.
Cause:
This issue generally Occurs when a Database from one machine is used in another machine, because Database may store some information of old machine.
Resolution:
If you are not able to select MC in management console selection screen as shown below then follow these steps:
If  the error you are facing is for Store MC then follow below steps:
1-In HO MC:
Go to Management Console >Administration>Retail Configuration>Management Console>Select the concerned store MC record.
2: The Below screen will appear. Remove the value from the Hardware Id section and click OK to save the results.
Once this information is updated at HO and replicated to store. Then you can try again by opening the Management Console.
If the issue persists please contact CitiXsys.
If  The error you are facing is for HO MC, please contact CitiXsys Support.
    • Can't see Management Console
      Environment : iVend 6.6 ( not version specific) Problem Statement: When Launched management console, it shows management console selection screen. However no Management Console record to select. Symptoms: Cause: Informed to customer that this issue ...
    • Unable to Open Management Console and POS Error message: Config Data not found
      Problem statement While trying to launch POS and Management Console system giving below error. “Config Data Not Found” Environment iVend Retail 6.6 7915 Symptoms Hardware Registration Problem Resolution/Work Around Solution Steps are below. 1: Login ...
    • Create New Screen for POS and Management Console
      Introduction This knowledge base article explains how to create a custom screen in the Management Console (MC) and the Point of Sale (POS). Purpose To provide developers with the ability to modify the existing MC and POS suite by adding their own ...
    • Management Console Licensing for On-Premise Customers/Cloud Customer
      Environment 6.6 integrated with SAP Problem Statement Management Console Licensing for On-Premise Customers/Cloud Customer Resolution/Work Around: There are two type of License on Management Console Licensing Device-based License Management and ...
