Modifying the Static text, Data Fields and UDFs
This article provides details on the modification of the static text, data fields and UDFs in the iVend POS Receipt.
Any user with basic XML and programming knowledge can customize the iVend POS receipts.
You can locate the Print Profile and Receipt Print Formats screens in the iVend Management Console in the following menu locations:
· Administration > Retail Configuration > Print Profile
· Administration > Retail Configuration > Receipt Print Formats
1. Select the Print Profile that is attached to the store POS, where the modification is required.
Figure 1 Print Profile Search
Choose the available print profile and click the [F4 Edit] button to edit the record.
You can edit the XML format of any of the following POS receipts however this cannot be performed directly within the Print Profile window. The user must export the design via the Receipt Print Format window (Receipt Designer).:
Figure 2 Receipt Designer
You can edit the XML format of any of the following POS receipts:
1. Labor Chit
2. Day labor Chit
3. Transaction receipt
4. XTape Report
5. Gift Receipt
6. Quotation Receipt
7. Expense Chit
8. Z Tape Report
9. CashInCashOut
10. Gift Certificate
11. Coupons
12. Customer Display Receipt
13. Payment Receipt
14. Suspended Transaction  Receipt
Modifying the Static Text or Labels in the Receipt
Sample XML:
<Row>
    <Element colspan="2" align="left" string="Item Sales" />
    <Element colspan="2" align="right" string="Cash Memo" />
 </Row>
Modify the string attribute of any “Element” element to modify the static text.
Modify the properties/data fields or UDFs in the receipt.
Figure 3 Receipt Designer-Store
Sample XML:
In the iVend POS Receipt XML structure, modify the following attributes of any “Element” element to modify the data field:
· object0: Refers to the object property for which the value needs to be printed. Mathematical calculations can be performed between the object properties.
· object1: Refers to the object property for which the value needs to be printed. Mathematical calculations can be performed between the object properties.
· string: Refers to the value printing of the properties defined in the ‘object0’ to the object<n> attributes. This attribute takes values as defined in the argument pattern ‘{<n>}’. Any Unicode character including Blank Space is allowed to be printed before or after the argument printing. Alternatively, this attribute can be used to print the label values without referring to the object values.
Note: The object<n> attribute can be defined until the nth number.
Click the  View Property List link to download an Excel spreadsheet for the full property list supported in the XML receipts. Refer to the 'Pivot' sheet and choose the desired object in the 'B2' cell. Accordingly, it will populate the table structure of the pivot and by further drilldown to the desired sub object you can choose the property in the 'E' column.
The following table lists the frequently used properties in the XML Receipts:
S.No
Section
Property
Description
1
Footer
AccountType
Payment account type .e.g. Credit, Debit, Cash, etc
2
Footer
Amount
Total Transaction Amount
3
Footer
AmountInSpanish
Total Transaction Amount in Spanish language .e.g. "doscientos mil solamente"
4
Layaway
ARPayments.LayawayBalanceAmount
Layaway Balance Amount
5
Layaway
ARPayments.LayawayOriginalAmount
Layaway Original Amount
6
Layaway
ARPayments.PaymentProxy.Amount
Payment Amount
7
Detail
ARPayments.PaymentProxy.OriginalDocumentId
transaction id of the document for which the payment is done
8
Detail
ARPayments.SaleOrderBalanceAmount
Balance Payment on Special Order in case advance payment is given
9
Footer
CardNumber
Credit or debit card number
10
Footer
CommentValue
Transaction comments
11
Footer
Customer.AccountsReceivable.Balance
AR balance of the customer
12
Footer
Customer.BillingAddress.Contact.FirstName
customer Billing Address Contact first name
13
Footer
Customer.DefaultContact.FirstName
Customer default Contact first name
14
Footer
Customer.DefaultContact.LastName
15
Footer
Customer.FirstName
Customer First Name
16
Footer
Customer.Id
Customer code
17
Footer
Customer.LastName
Customer Last Name
18
Footer
Customer.ShippingAddress.Contact.FirstName
customer Shipping Address Contact first name
19
Footer
GiftCertificate.BalanceAmount
Gift Certificate Balance Amount
20
Detail
GiftCertificateProxy.Price
Gift Certificate Price
21
Detail
GiftCertificateProxy.Product.Description
Gift Certificate Product Description
22
Detail
GiftCertificateProxy.Product.Id
Gift Certificate Product Id
23
Detail
GiftCertificateProxy.ProductDetailNumber
Gift Certificate Serial Number
24
Detail
GiftCertificateProxy.Type
Gift Certificate Type
25
Detail
26
Detail
LayawayItemProxy.DiscountAmount
Layaway Discount Amount
27
Detail
LayawayItemProxy.Price
Layaway Price
28
Detail
LayawayItemProxy.Product.Description
Layaway Product Description
29
Detail
LayawayItemProxy.Product.Id
Layaway Product Id
30
Detail
LayawayItemProxy.SurchargeTotal
Layaway Surcharge Total
31
Detail
LayawayItemProxy.Total
Layaway Total
32
Detail
33
Loyalty
LoyaltyCustomerSummary.AvailableCurrency
Loyalty Customer Available Currency
34
Loyalty
LoyaltyCustomerSummary.AvailablePoints
Loyalty Customer Available Points
35
Loyalty
LoyaltyCustomerSummary.AwardedCurrency
Loyalty Customer Awarded Currency
36
Loyalty
LoyaltyCustomerSummary.AwardedPoints
Loyalty Customer Awarded Points
37
Loyalty
LoyaltyCustomerSummary.CurrentSlab
Loyalty Customer Summary  Current Slab
38
Loyalty
LoyaltyCustomerSummary.FirstName
Loyalty Customer First Name
39
Loyalty
LoyaltyCustomerSummary.LastName
Loyalty Customer Last Name
40
Loyalty
LoyaltyCustomerSummary.LoyalityId
Loyalty Customer Loyalty Id
41
Loyalty
LoyaltyCustomerSummary.RedeemedPoints
Loyalty Customer Summary Redeemed Points
42
Detail
OrderItemProxy.DiscountAmount
Special Order Discount Amount
43
Detail
OrderItemProxy.Price
Special Order Price
44
Detail
OrderItemProxy.Product.Description
Special Order  Description
45
Detail
OrderItemProxy.Product.Id
Special Order  Id
46
Detail
OrderItemProxy.SurchargeTotal
Special Order Surcharge Total
47
Detail
OrderItemProxy.Total
Special Order Total
48
Header
Account Payment Original Document Id
49
Header
PrintDate
Transaction Date
50
Footer
PrintInformation
Greeting Message
51
Detail
Quantity
total sale item count of the transaction
52
Footer
ReasonCode.Id
Reason Code
53
Header
ReceiptStatus
Receipt label e.g. "Original receipt", "Duplicate receipt"
54
Detail
SaleItemProxy.DiscountAmount
Sale Item Product Discount
55
Detail
SaleItemProxy.Price
Sale Item Product Price
56
Detail
SaleItemProxy.Product.Description2
Sale Item Product Description
57
Detail
SaleItemProxy.Product.Id
Sale Item Product Code
58
Detail
SaleItemProxy.Product.ProductGroup.Description
Sale Item Product Group
59
Detail
SaleItemProxy.Product.UserDefinedFields!<FieldName>
Sale Item Product User Defined Field
60
Detail
SaleItemProxy.ProductDetailNumber
Sale Item Product Serialize and Batch
61
Detail
SaleItemProxy.ProductReturnDetailNumber
Sale Item Product Return Detail Number
62
Detail
SaleItemProxy.SurchargeTotal
Sale Item Surcharge Total
63
Detail
SaleItemProxy.Total
Sale item Total
64
Detail
SaleItemProxy.UOMGroupDetail.UOM.Description
Sale Item Product UOM
65
Detail
SaleItemProxy.UOMQuantity
Sale Item Product UOM Quantity
66
Header
SecurityUser.Id
Security User Id
67
Header
SecurityUser.SecurityUserType
Security User Type
68
Detail
SequenceNumber
Serial no  of the items in the receipt
69
Header
Store.Address.PhoneNumber
Store address Phone Number
70
Header
StoreInfo
id and description of the store
71
Footer
TaxCode.TaxRate
Tax Rate
72
Footer
TaxOnAmount
Total Tax Amount on Transaction
73
Footer
TenderAmount
Transaction Amount based on Tender Type
74
Footer
TenderType
Transaction Tender Type
75
Detail
TotalItems
Number of Transaction Items
76
Footer
TotalWholeString
Transaction Amount in words in English language
77
Header
Transaction.ActualDate
Transaction Date
78
Footer
Transaction.Customer.Address.Address1
Customer Contact Address
79
Footer
Transaction.Customer.Address.Address2
80
Footer
Transaction.Customer.Address.Address3
81
Footer
Transaction.Customer.Address.Country.Id
82
Footer
Transaction.Customer.Address.State.Id
83
Footer
Transaction.Customer.Address.ZipCode
84
Footer
Transaction.Customer.BillingAddress.Address1
Customer Billing Address
85
Footer
Transaction.Customer.BillingAddress.Address2
86
Footer
Transaction.Customer.BillingAddress.Address3
87
Footer
Transaction.Customer.BillingAddress.Country.Id
88
Footer
Transaction.Customer.BillingAddress.State.Id
89
Footer
Transaction.Customer.BillingAddress.ZipCode
90
Footer
Transaction.Customer.PaymentType.Id
Customer Payment method
91
Footer
Transaction.Customer.ShippingAddress.Address1
Customer Shipping Address
92
Footer
Transaction.Customer.ShippingAddress.Address2
93
Footer
Transaction.Customer.ShippingAddress.Address3
94
Footer
Transaction.Customer.ShippingAddress.ShippingAddress.Country.Id
95
Footer
Transaction.Customer.ShippingAddress.ShippingAddress.State.Id
96
Footer
Transaction.Customer.ShippingAddress.ShippingAddress.ZipCode
97
Footer
Transaction.Customer.UserDefinedFields!<FieldName>
UDF on customer
98
Footer
Transaction.DiscountAmount
Transaction Discount Amount
99
Footer
Transaction.DiscountPercent
Transaction Discount Percent
100
Layaway
Transaction.FulFillments.Address.Address1
Fulfillment Address (Delivery)
101
Layaway
Transaction.FulFillments.DeliveryDate
Fulfillment Delivery Date
102
Layaway
Transaction.FulFillments.PlanDesc
Fulfillment Plan Description
103
Layaway
Transaction.FulFillments.PlanId
Fulfillment Plan Code
104
Layaway
Transaction.FulFillments.StoreInfo
Fulfillment Store Info
105
Layaway
Transaction.FulFillments.StoreKey
Fulfillment Store Key
106
Footer
Transaction.Id
Transaction Id
107
Footer
Transaction.Key
Transaction Key
108
Footer
Transaction.PayableAmount
Sale Item Transaction Payable Amount
109
Footer
Transaction.POS.Id
POS Code
110
Footer
Transaction.SalesPersons.User.FirstName
Sales Person Frist Name
111
Footer
Transaction.SalesPersons.User.Id
Sales Person ID
112
Footer
Transaction.SalesPersons.User.LastName
Sales Person Last Name
113
Footer
Transaction.SalesPersons.User.MiddleName
Sales Person Middle Name
114
Footer
Transaction.ShippingType.Id
Transaction Shipping Type
115
Layaway
Transaction.Status.BalanceAmount
Transaction Balance Amount
116
Layaway
Transaction.Status.LayawayBalanceAmount
Layaway Balance Amount in current transaction
117
Layaway
Transaction.Status.LayawayPaidAmount
Layaway Paid Amount
118
Layaway
Transaction.Status.LayawayPayableAmount
Layaway Payable Amount
119
Header
Transaction.Store.Address.Address1
Store Address1
120
Header
Transaction.Store.Address.Address2
Store Address2
121
Header
Transaction.Store.Address.Address3
Store Address3
122
Header
Transaction.Store.Address.City
Store City
123
Header
Transaction.Store.Address.State.Description
Store State
124
Header
Transaction.Store.Address.ZipCode
Store Zip Code
125
Header
Transaction.Store.Description
Store Description
126
Header
Transaction.Store.Id
Store Code
127
Footer
Transaction.SubTotal
Transaction Sub Total
128
Footer
Transaction.SurchargesTotal
Sale Item Transaction Surcharges Total
129
Footer
Transaction.Tax
Sale Item Transaction Tax
130
Footer
Transaction.Tax.InnerValue
Tax with fixed currency symbol
131
Footer
Transaction.TotalChangeDue
Sale Item Transaction Total Change Due
132
Footer
Transaction.TotalRoundingAmount
Sale Item Transaction Total Rounding Amount
133
Footer
Transaction.TotalTaxableAmount
Total Tax Amount
134
Footer
Transaction.TransactionId
Transaction Id
135
Footer
TransactionPayments.AccountType
Tender Type
136
Footer
TransactionPayments.Amount
Total Payable Amount
137
Footer
TransactionPayments.Bank.Description
Bank Name
138
Footer
TransactionPayments.Bank.Id
Bank Code
139
Footer
TransactionPayments.CardNumber
Tender Card Number
140
Footer
TransactionPayments.GiftCertificate.BalanceAmount
Gift certificate balance amount
141
Footer
TransactionPayments.PaymentType.Id
Tender Name
142
Footer
TransactionPayments.TenderType
Tender Type
    • Need to Modify Sales Attribute property in iVend XML Receipts
      Environment: iVend 6.6 with patch 7723 Problem statement: Need to Modify Sales Attribute property in iVend XML Receipts. Symptoms: Not Applicable Resolution/Work Around: Modification of Sales Attribute property is not supported in iVend XML receipts. ...
    • Creating UDTs and UDFs
      Creating UDT and UDFs This knowledge base article will assist developers on how to create User-Defined Tables (UDTs) and User-Defined Fields (UDFs) using the iVend Retail API and the iVend Retail User Interface (UI). Purpose User-Defined Tables ...
    • iVend POS Data Shaping
      iVend POS - Data Shaping This article describes how to perform various data shaping operations (such as grouping, sorting and filtering) in the Dashboard Designer. The article contains the following topics: · Summarization · Grouping · Sorting · ...
