Not Environment Specific
Management Console shows an error message :
"No Management Console created"
Usually it comes, while starting the Management console application if the management console is not registered with the associated Store.
To make sure that the Management console is registered with the correct store, please go through the below steps.
1.) Go to the Enterprise(HO) Management Console.
2.) Then, Administration>>Retail Configuration>>Management Console
Note: Make sure that you enter the correct "Site ID" which is associated with the store.
3.) Then go to Then, Administration>>Retail Configuration>>Store>>View>>Registered Management Console
Note:- Make sure that you have the entry of that management console, which you have created for this store.
