There are two type of License on Management Console Licensing
Device-based License Management and User-based License Management
When a Management Console has been assigned a Device-based license, any Management Console user would be allowed to login from this Management Console machine (Device), For example – Multiple Users can login to the same device with their respective User IDs and Passwords.
A new screen Management Console has been introduced under the Retail Configuration Menu for creating device profiles for the Management Console.
To allocate a device based license user must check the flag “Has License” on the Management Console profile record.
When Management Console application is launched for the first time either on Enterprise Server or Store Servers, Management Console profile selection screen will be displayed and all the Management Console profiles corresponding to the Site ID will be listed. User has to select one of the profile from the list and then only he/she can login into the Management Console using their User ID and Password. Once profile is selected, Machine ID and Hardware ID will get automatically populated on the selected profile.
Device-based license allocation is only applicable only for On-Premise deployments of iVend Retail.
When a Management Console license is allocated to a User, the system would allow the user to log into any iVend Retail Management Console machine across the iVend Retail Landscape.
In order to allocate a license to a User, check the flag “Has License” on the Security User
For Cloud/Hosted deployments of iVend Retail Only User based licensing is available.
Only users with a valid User License can login in iVend Retail Enterprise or Cloud Stores.
