Loyalty menu does not appear
Problem Description
Scenario
Customer are trying to active and configurate loyalty functionalities in iVend, according to the documentation and videos,
they should see a menu option in MC, but, They can't find the option anywhere
Solution
Follow the below path and check Loyalty checkbox should be enabled
Open Management console --> Administration --> Enterprise --> Loyalty.
None provided.
