License Allocation Issues Caused by Inactive Users in iVend
Certain users who no longer exist in the Security Users list are still occupying active licenses, preventing the assignment of licenses to new users. Attempts to deactivate or remove these users have been unsuccessful, as they continue to appear as license holders despite being absent from the user management search. Assistance is needed to identify and remove these ghost users to free up licenses.
Response:
Here are the steps to remove security users occupying active licenses:
  1. Open the HO Management Console and navigate to Administration → Human Resources → Employee.
  2. Select the relevant Employee and click Edit, then set the status to Active.
  1. Verify the employee name as per the license information.
  1. Once the employee is active, they will appear in Security Users.
  2. Open Security Users and deselect "Is Management Console User" and "Has License" to free up the license.
Suggestion:
    • Check Support Contract Days
      How to Check the Number of Days for the iVend Maintenance and Support Contract All customers that are using iVend Perpetual Licensing, can check their time for renewal of their AMC (Annual Maintenance Contract) proactively and then start the renewal ...
    • License Expired, please contact vendor
      Problem Statement: Getting an error "License Expired, please contact vendor.". However, you are using a valid license. Solution: - Please follow below steps: - Please check the regional setting of the machine and make sure short date should be in ...
    • iVend 6.6 Performance Issues-Required SQL Index
      This KM is for Internal Purpose Only for CitiXsys Environment: iVend 6.6 Problem Statement: We have noticed that customers are facing performance issues with iVend 6.6. Symptoms: Environment Specific Resolution/Work Around: Technical Team has checked ...
    • Trigger on License information
      ------------------This article is for only internal use ------------------------ Product version: iVend 6.6 With SAPB1 10 Problem statement: User got the license expiry message however licenses were valid with their date. Symptoms: There are many ...
    • License Broken
      Environment:  iVend 6.6 and SAGE X3 Problem statement:  License Broken Symptoms : License Broken Resolution/Work Around: Flush the license key and active the new. Recommendations /Suggestion:
