XML receipt customization allows the iVend user with Basic XML and iVend object hierarchy knowledge to customize the receipts printed on the iVend Retail POS. Both static text and the transaction field data can be modified and mathematical functions can be applied at runtime on the field data. This section contains the following documents:
