iVend Retail - Report Timeout
iVend Retail –
 iVend Report (Designer) Timeout
Follow the steps mentioned below to set the timeout property in iVend Report Designer:
1. Open the Management Console, go to: Reports > Designer/Label > Report Designer
Figure 1 Report Designer
2. Open the report that is experiencing the timeout issue and from the Dictionary tab, select the Data Source, then right-click and select Properties.
Figure 2 Report Designer -Dictionary
3. On the Properties tab, "Command Timeout" property, the default value is 30.
Figure 3 Report Designer Properties
Figure 3
4. Change this default value as required. The time unit for the Command Timeout property is in seconds.
Note: Specify the value as 0 for unlimited time.
Figure 4 Report Designer -Command Timeout
Figure 4
5. After you have completed the desired changes. Click [Ok] to save the changes made in the report.
