iVend Retail 6.6 Extensibility AddOn Upgrade Process
Overview
The purpose of this article is to enlist the changes in Extensibility Add-On upgrade for iVend Retail 6.6.
iVend Retail 6.6 has significant framework changes due to which changes would be needed in existing add-on projects running on iVend Retail 6.5.X
Without these necessary changes existing add-on will cease to work or result in errors on iVend Retail 6.6
This presentation highlights the necessary changes and explains the process to change code step by step
Existing numeric data in the primary key fields is not an issue. No action is required in iVend Retail 6.6 upgrading process
This presentation is intended for programmer/software architects
How do I get started?
The following are the steps to upgrade the Extensibility Add-On in iVend Retail 6.6:
Upgrade your existing Development Environment of iVend Retail 6.5.x to iVend Retail 6.6
Install DevExpress v18.1 (though this is an optional step, we still recommend the installation of v18.1)
DotNet framework 4.5.2 developer version needs to be installed on the Development server/machine
Execute steps 1 – 10 detailed in the slides below
Once the Add-On is compiled, install and test the Add-On in the upgraded environment of the customer for Unit Testing
Change 1 – Primary keys are now GUIDs
In iVend Retail ver. 6.6, all primary keys are now GUIDs. Therefore, primary key for any UDT (user defined table) would be created as data type ‘nVarchar’ instead of ‘BigInt’.
On upgrade from previous version of iVend Retail, Installer will do the necessary changes in the DB structure while upgrading the base iVend product.
Any existing Add-on program do not need to make any change in the primary key of existing UDTs while upgrading the add-on to the latest version.
However, if any reference key has been created in any UDT to make the foreign-key relationship between any two DB tables. i.e. primary key of any UDT referenced in another UDT field, that must be converted to data type ‘string’ in add-on code. This will result in ‘nVarchar’ db type in the table structure in the database.
iVend Retail ver. 6.5.X DB table structure and data type for primary key
iVend Retail ver. 6.6 DB table structure and data type for primary key
Change 2 – Variable change in the add-on code
Once the Base iVend retail is upgrade to ver 6.6., DB structure is modified at primary key level. •However, datatypes for all variables, properties, method parameters associated with ‘Primary Key' of the UDT would be changed from ‘Int64’ to ‘string’
iVend Retail ver. 6.5.X compatible code sample
iVend Retail ver. 6.6 compatible code sample
 Change 3 – Initialization of variables
• Initialize these ‘Primary Key' variables with ‘string.Empty’ instead of ‘0’ (If it is already initialized with numeric zero ‘0’ anywhere in the code)
• To validate string primary key fields and variables for ‘null’ values, compare with ‘string.Empty’ instead of numeric zero ‘0’
Change 4 – Best code practices
• For all existing variables to handle primary key fields, Convert Nullable<Int64> variables to ‘string’ data type as string is nullable by default
• No code or data change is required for the existing data in the database for the primary key fields
• Necessary changes are required in existing T-SQL queries written in the Add-on code.
Change 5 – Dexexpress UI component reference upgrade
Incase, the previous add-on is using Devexpress UI components for custom GUI screen, then all  DevExpress references would be updated to the DevExpress v18.1 only.
Change 6 – New method for Searchview screens
• ‘searchview.AllowBusinessObjectEditing’ property in SearchView screens has been obsolete in iVend Retail ver. 6.6 • ‘searchview.SetAllowBusinessObjectEditing(boolean flag)’ method would be used in lieu of obsolete property Existing property reference
Change 7 – T-SQL level changes in the addon
The SQL queries (in add-on)  where key is appended, single inverted commas (‘ string‘) would be includes at start and end of string.
Type cast the primary key value to ‘nvachar’ for any comparison in sqlqueries  ( in case type casted any where in ‘bigint’)
Convert(bigint, U_CXS_USERDEFINEDTABLE.U_CXS_USERDEFINEDTABLEKey)
            should be converted to
Convert(nvarchar(50), U_CXS_USERDEFINEDTABLE.U_CXS_USERDEFINEDTABLEKey)
Change 8 – Handle return value from SQL in add-on code
In some cases, changed key columns (now nvarchar)  in SQL queries will return "0" in string format instead of string.Empty. This case should be handle as mentioned below.
if (!string.IsNullOrEmpty(keyStr) && Convert.ToInt64(keyStr) >0) {
Change 9 – Add-on compatibility for Any CPU compilation
In Configuration Manager select the option “Any CPU” at the time of add-on compilation
Change 10 – Support only X64 compatible 3rd party components
Any third party dll which is needed to be referenced in add-on must be X64 compatible
Change 11 – Custom Report Changes
All Custom reports are required to be re-verified.
Custom Report SQL Queries must be changed in accordance with the changes mentioned in this
document.
Artifacts
iVend Retail 6.6 BETA release note link
CKP ->link
iVend Retail 6.6 Beta Setup link
CKP-  Setup
iVend Add-on upgrade process PPT is attached with this article for reference purposes.
