iVend Initialization : Duplicate Item/BP Code Exists in BP Catalog
iVend 6.6 With SAPB1 9.2
Problem Statement :
While initializing iVend with SAPB1, it displays the error message :
Symptoms :
User configured the iVend Configuration and click on Initialization button to start the iVend initialization process.
Not Applicable
iVend functionality does not allow duplicate BP/Item catalogs there it is restricted iVend. It suggest to rectify the duplicacy in SAPB1.
Integration Error "invalid BP Code"
Problem Statement Integration Records are stuck in Integration Failure Monitor with the error message "invalid BP Code" and "This entry already exists in the following tables" Resolution/Work Around If this error is reported in the older versions of ...
Duplicate product code appear on Management Console
Environment: 6.5.6 SAP B1 Symptoms: Duplicate product code appear on Management Console Problem statement: Duplicate product code was showing on Product search. We noticed from these items one item is created from Enterprise and second one created ...
Business partner catalog number linked to item not specified as sales item
Product Version :- 6.5 update 6 Problem Statement :- Records stuck on Integration Failure with Error message "[INV1.ItemCode][line:70], "Business partner catalog number linked to item not specified as sales item (1)" from SAP to iVend Solution :- ...
System.Exception: DI: [POR1.ItemCode][line: 1] , 'Business partner catalog number linked to item not
Problem Statement: Transaction stuck between SAP To iVend. Error: System.Exception: DI: [POR1.ItemCode][line: 1] , 'Business partner catalog number linked to item not specified as purchasing item (1) Propose Solution: Login in SAP Business One. 1: ...
