6.6
Problem statement
INC0016944 When user trying to create a GRPO from management console when customer click new and choose any PO it does not show any error and revert back to GRPO search screen.
Proposed solution: -
As a workaround suggested user to disable the parameter Is display only on Purchase order User defined fied.
Issue is only reported on Base version of 6.6 and is already fixed in the latest branch of iVend release available for the production use.
Steps if any:
1.Created User define field test1 SAP Tools->Customization Tools ->User-Defined Field-Management->Click on Marketing document->Add field
2.Go to Administration->System Initialization->iVend Retail->Marketing document Udf Integration ->Select object Purchase order and Click on Integrate so that it will integrated into ivend
3.Open User Defined Field of purchase order in ivend and enabled Display only parameter on test2 field and click on ok system will show message “Database schema has changed ,application requires restart .Do you want to restart now? Click on yes
4.After that trying to create a GRPO from management console when customer click new and choose any PO it does not show any error and revert back to GRPO search screen
Constraints / scenarios :
