iVend Extensibility
iVend Extensibility
We put all the power in your hands with iVend Extensibility. Our platform offers you the ability to customize and add on to create a system in total sync with the way your store runs. With the solid foundation of iVend Retail and our built-in extensibility, your system will never go out of style.
Add-on Development
The ability to customize and add on to create a system in total sync with the way your store runs. With the solid foundation of iVend Retail and our built-in extensibility, your system will never go out of style.
iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows to extend business logic either in Management Console or at the Terminal POS. The Addon framework allows deployment of multiple Add-Ons on one Enterprise. The extended business logic is deployed as an Add-on centrally at the Enterprise which then gets auto-replicated to entire retail landscape.
iVend Retail Add-on framework is used for extending GUI, writing Custom Business Logic and enhance application functionality.
Multiple add-ons can be run parallelely and can be prioritized as required on specific iVend Retail stores.
iVend Retail Add-on allows to extend business logic on the Management Console and the Terminal POS only
Click HERE to learn more about iVend Extensibility
