iVend Document series import issue ,issue was related to import POS Document Number Series
At the time of creating the POS Document series through import utility only the last row of excel is imported. Incident ID - INC0012396
Provided the latest patch of 6.5 Update 6  for production use.Issue is only reported on dated version and is not noticed on the latest branch of iVend release available for the production use.
Steps if any:
Constraints / Scenarios:
Scan Sequence Resolution
Documents not integrating in SAP with correct number series.
Problem Statement: Documents not integrating in SAP with correct number series. Issue Detail: Customer has defined a new Document number series for A/R invoice in SAP B1 but still A/R invoice integrating with previous Document numbering series. ...
Import Serial Coupons
Import Serial Coupons Enhancement has been done on the Import data screen by adding “CouponSerialNumber” to object type. This will facilitate import of valid range of serial numbers created from another system to be issued by serial number from the ...
iVend Price Mismatch on Store, issue was related to replication skipped.
Product Version: 6.5 Update 6 Problem Statement: INC0012660 : iVend Price Mismatch on Store, issue was related to replication skipped. Proposed Solution: This issue can be resolved by sql query. Issue is only reported on dated version iVend ver. 6.5 ...
