iVend Demostack Installation
iVend Demo Stack Installation:
iVend Demostack enables the CitiXsys iVend Retail partner’s sales team to position and demonstrate iVend Retail to their prospects with great ease. The DemoStack with relevant demo data configured for different retail verticals will enable consultants to showcase how end-customers can utilize the iVend Retail Management Suite to extend to their customers an experience that is engaging, personal and rewarding.
iVend DemoStack makes it easy to set up the demo environment effortlessly. iVend DemoStack is an all in one installer which can be used to set up a demo system with all solutions in the iVend Retail Suite including pre-configured data. The DemoStack is a logical collation of all the complementary applications of the iVend Retail Management Suite including:
  • iVend Terminal PO
  •  iVend Loyalty
  • iVend Handheld
  • iVend Passes
  • iVend Mobile POS
The iVend DemoStack has a built-in demo database which enables transacting on a Terminal POS, Mobile POS and Handheld. It also allows the sending of Digital Passes and the awarding and redemption of Loyalty points. It empowers partners to showcase the integrated retail experience to prospects right from the demo system.
iVend Demo Stack Installation Guide:
This document, which can be downloaded from the CitiXsys Knowledge Portal, will help partners successfully install the iVend Retail DemoStack – refer download link below.
It helps partners prepare for installation by describing the system prerequisites and then steps through the installation process.
iVend Retail DemoStack installer includes a full pre-configured set of all the integrated applications of the iVend Retail Management Suite.
It includes comprehensive demo data across all masters and configuration settings, coupled with detailed explanations of the master data and makes it far easier for pre-sales, sales and implementation consultants to showcase the power of the iVend Retail Suite and ultimately enables end-customers to easily and quickly evaluate the products on offer.
The applications included in the DemoStack are:
  • iVend Terminal POS
  • iVend Management Console
  • iVend Handheld
  • iVend Passes
  • iVend Loyalty
Follow the link below to download the iVend DemoStack Installation Guide to learn more:
iVend Installation Guide:
Only registered partner users of the CitiXsys Knowledge Portal will be able to download this document.
