Item Matrix (5.9.5 ) Add-on for 64 bit Addon
Information:
This knowledge article can be referred to, for the item matrix add-on (for 5.9.5  version)
Attached is the 64 bit add- on for Item Matrix  (5.9.5)
    • Ivend Item Matrix Addon not able to connected
      Environment : Item Matrix 5.9.6.0 Problem statement: Item Matrix Addon not able to connected Symptoms: SAP user not mark Item Matrix User Resolution/Work Around: Need to check SAP user should be Item Matrix user in SAP. Recommendations /Suggestion: ...
    • Item Matrix Global Settings
      Item Matrix Global Settings This feature allows the user to define the Global Code and Inheritance settings for Matrix Items. These settings are used as the system defaults and are inherited to the Matrix products in the first instance. The user can ...
    • Item matrix Add-on version Compatible with SAP 10
      Environment : iVend 6.6 integrated with SAP B1 Problem statement : Which item matrix Add-on version Compatible with SAP 10 Symptoms : If Customer used older Add-on version(5.9.4.0) with SAP 10 then it showing connection timeout at the time of setup ...
    • Item Matrix Add-on restart after applying the license
      Environment : Item matrix 5.9.6.0 update 5 Patch FP 2105. Problem Description : Item Matrix Add-on restart after applying the license. Possible cause : License was not installed properly or full permission not given to SAP folder . Troubleshooting ...
    • License Error For Item Matrix User
      Product version: Item Matix 5.9.6.0 Problem statement: Customer has informed that they were getting the license error for the users when they use to add child item to the parent item and one user can work at a time. Symptoms: Environment Specific ...
