Failure Integration Event :Vendor Group not found in iVend
iVend 6.6 integrated With SAPB1
Problem Statement :
CustomerGroup add events stucked on Integration Failure Monitor from SAP Business one To iVend with below Message “System.Data.SqlClient.SqlException (0x80131904): String or binary data would be truncated.
The statement has been terminated”
We checked below point :
In SAP screen we checked that problematic Vendor group name showing Vendor group setup screen not showing in iVend screen.
It is the part of OCRG table of SAP database.
Vendor group also part of integration mapping table however is not integrated .
Later we analysis data and found Vendor group name string length is more than 20 character and and iVend only allowed desc upto 20 character .
Suggested customer to check length of VendorGroup name in SAP. iVend only allowed desc upto 20 character.
We can check problematical item group by execute below query in sap.
SELECT len(GroupName),GroupName FROM OCRG where len(GroupName)>20
