Issue with report "Item with no sales report"
There is an issue with the report "item with no sales report " which is pulling the wrong data.
Proposed solution:
First check which item with no sales report is pulling is in suspended mode or not.
If the item is in suspended mode then the report will pull the data.
Because the suspended transaction means there is no any sale for item .So mark the suspended item as "is deleted"
after that report will not pull the data.
SALES BY CUSTOMER REPORT ERROR
Problem statement SALES BY CUSTOMER REPORT ERROR Environment IVend 6.6 Symptoms After upgrading to version 6.6 from iVend version 6.5.6, SALES BY CUSTOMER REPORT is coming blank. Resolution/Work Around We have checked and found that "Sales by ...
iVend Sales comment Integration issue in SAP
Environment: iVend 6.6 with patch 7989 integrated With SAPB1 Problem Statement: iVend Sales comments didn't integrate into SAP B1 and can't be seen in SAPB1 AR Invoice. Symptoms: NA Resolution/Work Around: Issue is reported on iVend 6.6 with patch ...
Optical Add-on issue: Few Products are not showing in the POS Error appears "No item To resolve"
Product version: 6.6 with Optical Add-on Problem statement: Few products (eg Color lens) are not showing at the POS. Error message appears "No item To resolve" Observation: All problematic products are not visible on the optical screen of the POS for ...
Unable to Export "Top Item Sales By Quantity or Price" data in Microsoft Excel
Problem statement Unable to Export “Top Item Sales By Quantity or Price” data in Microsoft Excel. Environment iVend 6.6 7825 SAP B1 9.3 PL 14 Symptoms The problem was related with Microsoft Export Setting configuration. Resolution/Work Around Need to ...
Blank CSV file while exporting Sales Report
Environment: iVend 6.6 Problem statement: When trying to export from the Sales Report to CSV, the system producing a blank CSV file. Symptoms: The process appears to work on all other reports and also works like on Excel Export. Steps: 1. select ...
