Is there any way to remove the products from appearing on the management console?
Would a store be be able to transfer an item of stock that is on hold to another store?
We cannot remove products from appearing on the management console.
Once the product is marked as OnHold in ivend then the store will not be able to see the product for making the transfer and also if it is transacted on POS then it will show as "Product is on hold"
