Is it possible to create UDF on iVend Objects (Store, Enterprise) using Extensibility?
Query:
Is it possible to create UDF on iVend Objects (Store, Enterprise) using Extensibility or UDF on iVend Objects can be created only using Management Console?
Answer:
UDF can be created on iVend objects through extensibility.
Please find the sample code as mentioned below: -
UserDefinedTable userDefinedTable = UserDefinedTableSubSystem.Instance.Load(typeof(Store));
UserDefinedField userDefinedField = userDefinedTable.CreateField();
userDefinedField.FieldName = "U_ABC";
userDefinedField.Description = ""U_ABC_Description";
userDefinedField.DataType = UserDefinedFieldDataType.String;
userDefinedField.DataLength = 100;
userDefinedField.IsSearchable = false;
userDefinedField.IsMandatory = false;
userDefinedField.DisplayOnly = false;
userDefinedField.ShowInResults = false;
userDefinedField.RegularExpression = "";
userDefinedTable.AddField(userDefinedField);
CXS.Retail.BusinessLogic.UDFHelperClass.CommitUserDefinedFields(userDefinedTable);
