Inventory of products is not updating in iVend when a miscellaneous Receipt is created in Sage X3.
iVend Version 6.6
Inventory of products is not updating in iVend when a miscellaneous Receipt is created in Sage X3 for a product.
Tender mapping is not present or incorrect for the concern store.
Create/correct the Tender mapping in configuration manager of iVend for Sage X3 as shown below:
Not Applicable
Require to make the inventory as Zero for particular store
Sage X3 Ivend Integration Issue-New Products and Delta Inventory from X3 not updating back in Ivend
Problem Reported Customer created an Item in Sage ERP X3, with product code TESST1( Any product Code ), received some inventory using miscellaneous receipt and it has not updated Ivend after several hours. Cause There is a possibility that there are ...
Multiple Receipt Printing issue
Not able to integrated Sage X3 newly created product in iVend
Environment: iVend Version 6.6 With Sage X3 Problem Statement: New products were created in Sage X3 but not able to integrate with iVend. Symptoms: New products were created in Sage X3 but not able to integrate with iVend. Resolution/Work Around: ...
Goods receipt not integrating to Sage X3 when initiated from iVend
Environment: iVend 6.6 Patch 7747 Problem Description: Goods Receipt transaction not integrating to Sage X3.Subsequent transactions like Goods return, Goods Issue etc are stuck in the integration monitor. Scenario: When creating the Good Receipts for ...
