Inventory Mismatch between Enterprise and store
6.6
INC0012329 Inventory Mismatch between Enterprise and store or skipped transactions from Store to Enterprise due to some issue n Replication.
Proposed solution:
Suggested customer to deployed the fix as per below step.
Steps if any:
We are required to follow below steps:
1)Download the link https://citixsys.com/files?/share/view/20mfo-bp1mtprt-a1uybdou
2) It contains three files i) TableScript.txt ii) ProcedureScript.sql iii) iVendReplicationEngine.rar
3) For File i) TableScript.txt ii) ProcedureScript.sql , Go to iVend enterprise, Stores, offline POS( if exist) database and apply SQL Script manually with taking database backup
4) For File iii) iVendReplicationEngine.rar, it is Replication Engine files , when you unzip it , you will find i) files ii) bin Folder files
5) Go to iVend Enterprise Replication Machine -->C:\Program Files (x86)\CitiXsys\iVend Retail\iVendReplicationEngine --> Take the backup-->Copy the files
6) Go to iVend Store Replication Machine -->C:\Program Files (x86)\CitiXsys\iVend Retail\iVendReplicationEngine --> Take the backup-->Copy the files
Constraints/Scenarios:
