iVend 6.5 Update 6 or 6.6 with SAP B1
Integration records were duplicate and stuck in integration failure monitor from iVend to SAP B1.
Configuration Issue
We have checked that multiple integration services were running and because of some of records were duplicate from iVend to SAP B1. Checked that windows services screen and found the same. We have disabled the integration services which were not in use and verified only respected integration was running now.
Please make sure should not run multiple services for iVend integration and should be disabled unused services.
