iVend Version 6.6 with SAPB1 9.2
There is purchase order stucked in Integration failure from iVend to SAPB1 :
Error message : --System.Exception DI 480000079 Inactive tax code [VI5]; specify an active tax code or activate this one at ReplicationSBOIntegrationWinSer.IntegrationObjects.PurchaseOrde.CreatePurchaseOrder(DataRow[] objDataRow, Direction From, Direction To, String iVendSBOPONumber, DataSet ObjDataSetSurcharges, Int32 OperationType, DataRow[] objDataRowUserDefinedFields) at ReplicationSBOIntegrationWinSer.IntegrationObjects.Transactions.Replicate(Direction From, Direction To, Int32 DatasetRowID) at ReplicationSBOIntegrationWinSer.Integrator.MainStart(DateTime LastRetryAt, Boolean Retried)
Purchase order was raised in iVend and it tries to integrate with SAPB1 .
Suggest to check the applicable PO tax code in iVend active/inactive and in SAP as well. If in SAP inactive then activate the applicable tax code and retry the stuck records.
Recommendations /Suggestions
It is suggested to keep the masters same in SAPB1 and iVend.
