6.5 Update 6
Problem Statement :
Record stuck from iVend to SAP in the Integration Failure Monitor with the below error message
"UoM Entry does not found in integration mapping"
Resolution :
1) Check the UOM and UOM Group definitions in SAPB1 and iVend Enterprise MC/Database
2) Check the CXSIntegration table Integration mapping for objects UOM and UOM Group . Integration mapping contains the object mapping between SAPB1 and iVend Enterprise
3) Check the InvUPCTranslation table and it might be set to isDeleted due to which this error comes .
select isDeleted, * from InvUPCTranslation where UPCTranslationkey='mention the UOM key'
4) If UOM UPC definition is marked as deleted, such integration failure will not be integrated from iVend to SAPB1.
Workaround : Such events can be ingored from iVend to SAPB1 but it should be done by Support team
