Integration error "System.Exception DI 10000146 Enter valid code"
iVend Version 6.6
Error in Integration failure monitor in Enterprise Management console for Source Type Stock-Transfer & Good-Receipts (34 & 53).
System.Exception DI 10000146 Enter valid code at ReplicationSBOIntegrationWinSer.IntegrationObjects.InventoryStockTransfer.CreateInventoryStockTransfer(DataRow[] objDataRow, DataSet objDataSetSerialBatch, Direction From, Direction To, String iVendSBOSTNumber, Boolean IsGoodReceiptST, DataRow[] objDataRowUserDefinedFields)
at ReplicationSBOIntegrationWinSer.IntegrationObjects.Transactions.Replicate(Direction From, Direction To, Int32 DatasetRowID)
at ReplicationSBOIntegrationWinSer.Integrator.MainStart(DateTime LastRetryAt, Boolean Retried)
iVend To SAP Business One
Integration Key
Source Type
Source Key
Action
Log Date Time
Error Message
0B89209C-4CA2-4BB0-86DC-EFBCE252D042
53
7f068f9-cdea-4680-9c75-3f2e81793001
0
4/9/2021
at ReplicationSBOIntegrationWinSer.IntegrationObjects.Transactions.Replicate(Direction From, Direction To, Int32 DatasetRowID) at ReplicationSBOIntegrationWinSer.Integrator.MainStart(DateTime LastRetryAt, Boolean  Retried)
23FCA748-8F0C-439E-AC59-FAB38DFA8AFB
34
94525113-76e8-437f-81b3-9c06d84227b3
0
4/8/2021
It was observed that the corresponding assigned Project code was not correct in SAP, so the customer updated the project code with a correct Project code in SAP, after that retried corresponding failed records in iVend which synced in SAP successfully.
Not Applicable
